Interior grounds?
EvoByDarwin
I suppose Ill make this my "newb" intro, Im on a lot of automotive forums and just picked up a SN95 car. Used to have a 95 Cobra and missed it so much I had to get in another. Anyway on to the issue at hand
I purchased a 95' Mustang GT with a electrical gremlin. The previous owner claimed that the following all stopped working simultaniously:
Speedo
Dome light
Keyless entry
Doorlocks
Clock
Ive done a little prodding around in AllDataPro and it looks as if these circuits are tied into the same ground? So this leads me to believe that Ive got a bad ground or a possible short in a wire somewhere. Ive checked all grounds I was able to find under the hood but havent found any inside the car to check.
Another note of interest is the previous owner claimed that this happend about a day after installing new carpet, any grounds under there?
Any help is greatly appreciated!!
Paul
There are several miscellaneous grounds under the dash. Have you checked the fuses?
g36 monkey
Orlando, Fl
I pulled alot of my carpet and I saw grounds under it I do believe. May be a place to check. However, someone on here may know more considering mine is "new edge" or whatever.
fuses are also good to check
More likely its gonna be a fuse,same thing happened to me a few weeks ago.
Hope this helps.
