Irs swap 95 gt
stroked95
What all do in need to do a irs swap into a 95 gt i have access to a 01 cobra(i think its a 01)? Will the irs out of a 01 work in a 95?
Thanks for any help.
white95
Apex Junky
Prairieville, LA
It will fit!! You have to drill a few holes for the rear subframe mounts. You also have to adapt your brake lines to the IRS lines. You either need the driveshaft from the 01 or a hybrid u-joint. You'll need the springs, shocks and exhaust from the '01. That's the short answer.
95riosnake rz5.0 330CubeGt dutch - have completed the swap and will provide better answers/pics [MENTION=18321]z06killa[/MENTION]
rz5.0
Great state of TEXAS
Its easy get all the hardware from the irs..you have to make new brake hard lines.
Drill some holes for the subframe.. Every thing else just bolts on. You won't reuse anything from your staight axle..
96TANGERINEGT
DO IT !!!!!!!!!! Its a killer swap .. unless ur gonna make a complete racecar ..
rz5.0
I used the cobra drive shaft.. It was shorter but i set the engine back witch made up for it..
I got the u joint but not a fan of grease able u joints of it was a solid u joint i might have stay that way.
LucasaLutian
USA
You have to routine a few gaps for the back sub frame installs. You also have to evolve your braking mechanism collections to the IRS collections. You either need the drive shaft from the 01 or a multiple u-joint. You'll need the rises, excitement and fatigue from the '01. That's the brief response.
cobraracer46
BFE
Do you plan on leaving the IRS stock or are you planning on changing the IRS suspension bushings? What are goals for the car?
white95
Apex Junky
Prairieville, LA
I have the Moog 448 in a box for my swap, just have to find an IRS pinion yoke. Thinking about installing my IRS with the oem bushing (except the F&R differential mounts) until I can sell my 8.8 to fund the rest of the bushing kit.
stroked95
stroked95
Thank you all for the help. As plans for the the car to make a better driving and handling car, the roads where I live suck, so I figure if I do the irs swap would ride better. I do plan on upgrading all the bushings and putting new axle shafts in while it is out along with the bearings. I can get every thing to swap beside bushings, axles, and bearings for 300( rear end, springs, drive shaft). Is there a difference in the 99-02 irs and the 03-04 irs? I know the axle shafts are different.
95riosnake
Pittsburgh, PA
The diff/axles on the 99/01 units are 28 spline rather than the 03/04's 31 spline, I replied to your pm :thumbsup:
Look into the Full Tilt Boogie Racing bushing kit also, I have everything they make for the IRS and the quality is top notch.
cobraracer46
BFE
If you are looking for a better ride, the factory rubber will be the best bushing choice, especially if you drive on crappy roads. The 2003-2004 Cobra IRS factory rubber bushings are 400% stiffer than then the 99-01 versions. Poly bushings will be a lot stiffer than the factory rubber and it would be the stiffest bushing I would run on the street. I would advise to stay away from delrin and aluminum bushings and mounts for your IRS as you mention that you want a good ride as the delrin and aluminium come with a significant penalty in ride quality, especially on rods that suck.
As mentiond, the 03-04 IRS has rubber bushings that are 400% stiffer than the 99-01 versions
Other 03-04 improvements:
1. inner tie rod mount was lowered to reduce roll understeer.
2. sway bar has higher grade steel ends.
3. stronger ball joint races.
4. tubular cross brace with extra mounts for the differential center section.
5. stronger axle shafts than the 99-01 versions
In short, id would be advisable to get a 03-04 IRS set up as that would allow you to leave the factory bushings alone if you wanted too while still getting a significant handling improvement. Some people change the IRS bushings to try and solve wheel hop issues and rear end sway conditions , but none of those problems are caused by the IRS bushings.
Check out my IRS thread on this form for more IRS info
http://sn95forums.com/showthread.php?58644-Upgraded-the-IRS-Cobra-suspension-with-Poly-and-more
96GTPlanB
Staff online
