Hey guys, i have a 94 mustang gt that is stock besides a k&n filter, o/r h pipe and 3 chamber flows. My problem is that under hard acceleration, the car momentarily pings then climbs through the rpm fine, but without too much power. The car is at sea level with the timing set at 9 degrees and i run 87 octane with a new fuel filter. I did a fuel pressure test and it idles at 32psi and jumps to 40 when i stab it, but then the psi goes down to a steady 30psi when i keep the throttle open . Without the vacuum line connected the pressure goes to 42psi at idle. Both my pump and regulator are stock with about 140k miles. Is this normal or is one of my fuel components going out on me? Also, a mechanic told me to pinch the fuel return line and that it should be around 80 psi; is this an accurate way to check the fuel pump? Any advise or comments would be appreciated. Thanks!
