Look under the glovebox (dash) you will see a grey plug with 2 connections. turn the key forward and wait for the flashing to stop on the first set of flashes (there should be 2 sets of flashes). at that moment, insert a jumper wire like a paper clip into the plug and hold it. if you did this right you should hear a loud beep after about 5 seconds of holding it. if you didnt do it right then turn the key off and turn forward again to repeat the flashing. remember, its after the first set just before it goes and flashes its second set
GOOD LUCK BECAREFUL
GOOD LUCK BECAREFUL
