It's too heavy eh??
Werecow
Werecow
Virginia
TBH unless I can get some good, and I mean good welding repairs done on my motor mounts and k-member after I get it running and back in street able condition, I'll be looking seriously at that big block swap on mine.. It'll most likely be a 460 unless I can get my hands on a 429 bottom end... And... Nooooo with aluminum heads, intake, water pump and battery swap to the trunk they're not as heavy as ppl think they are.. I've been doing my research on the big block forums..
Werecow
Werecow
Virginia
Just for reference.... A bare 460 block only weights about 10-15 lbs more than one of the LS iron blocks some douchebags are cramming into our beloved ponycars these days...
evilcw311
Most Evil Member!
Louisville, KY
Yeah but the huge heavy cast heads and intake build weight quickly.
Stucco with aluminum heads, intake, and billet accessories and you’ll easily keep the weight down
if anyone needs to loose weight let me know and I can hook you up with the peruvian diet that keeps me thin. Its cheaper than the southbleach diet as you do not need to buy the coke its more of a combination of bulimia and anorexia and it can make you drop 20 lbs in a matter of days.
Werecow
Werecow
Virginia
And the meth you can even make at home for the cheap!!!
*Disclaimer* this forum does not condone the use or manufacturing or illegal drugs of any kind kids, just so you know and "Breaking Bad" was really just a TV show...
