I've tried everything at this point.
95opal
The ecm has a preprogrammed table it will run off of if it doesn't receive signal from the lambdas.
The misfire would likely be bad coil bad PIP or MAF. And or bad wiring in the ignition circuit. Even without the o2s the car should still run probably on the rich side.
lutter94
South Dakota
This guy is a troll. Tries to say no o2 sensors but hasn't posted one photo. Started out with poor communication, why not end it that way as well. This thread feels too much like a Facebook post.
dirrkdiggler420
dirrkdiggler420
It was timing
Can you elaborate and let us know what happened?
So im starting to think it was a bit of it not having gas. Timing and the egr valve. We unplugged the egr put more gas in it and got the timing on point with a light. However i believe timing was the biggest problem. And as far as me trolling i work 12 hours a day and go to my family i dont have alot of time. The car was one owner till i bought it. I found the front clip needed to be done so i pulled the motor and started having a bunch of issues. Car is a 5 speed 5.0 its all there however the owner before me made alot of mistakes. Thank you guys for the help
LEGALLYFAST
I agree with @ttocs. The excess fuel can and will likely cause you many different problems later. So even if you figured out the issue now, it’s to your benefit to correct this.
alleghenyamerican
