95DarkGreenGTS
ok to do the lower control arms where do i place the jack stands in the rear of the car? I usually place them on the rear end
OnyxCobra said:I always put mine on the frame, i believe its right in front of where the lower control arm bolts to the car.
toucheee, but yea you def had the right idea with the torque boxes. there are 4 on every car one in every corner of the cabin. thoes are the strongers points of a car and very very crutial to measuring a frame if your doing it by hand or pulling it after a carsh.OnyxCobra said:I guess if you get technical, i mean the subframe connectors connect the subframes don't they?
duff daddy said:toucheee, but yea you def had the right idea with the torque boxes. there are 4 on every car one in every corner of the cabin. thoes are the strongers points of a car and very very crutial to measuring a frame if your doing it by hand or pulling it after a carsh.OnyxCobra said:I guess if you get technical, i mean the subframe connectors connect the subframes don't they?
