I have a 1995 Mustang GT (AODE) that was recently swapped to a T5. The swap went smooth, but now I have some serious driveability issues.
The car shifts and drives fine now except a misfire/bucking/dead spot at around 4k rpm and 5800rpm and cruising in 5th at about 15% throttle between 1800-2300rpms.
I bought a used 1995 Cobra 5spd ECU and plugged it in and the car wont even drive. Feels like a spark plug wire or two are unplugged. No power and wont accelerate. So I bought a 1995 GT 5spd ECU and plugged it in and it does the same exact thing. The car will hold idle but it sounds like a radical cam (im stock internals). When I plug the Auto ECU back in the idle is fine and it drives but still with the other issues originally noted.
I have some stored ECU codes but they all relate to the auto transmission and when it was giving out.
Ive changed/checked all the parts below:
(1) New TPS sensor calibrated to specs
(2) New cap and rotor
(3) New motorcraft spark plugs gaped to .48-.50
(4) New motorcraft spak plug wires
(5) New fuel filter
(6) Checked fuel pressure which is a 37-40psi
(7) MSD iginition coil
(8) Timing set to 10degress (stock)
(9) New King Cobra clutch/new pressure plate/resurfaced flywheel
(10) Cleaned MAF
(11) Fresh tank of 93 Octane
(12) New ignition control module
Any help/suggestions would be appreciated
**** MODS - shorty headers, off road H pipe, flowmasters dumped. 4.10gears (stock everything else down to the paper air filter) ****
(5) New fuel filter
(10) Cleaned MAF
