Just got a ***** in my chain, need some serious advice
dafizuck
I typically get frustrated at threads like this, but I am looking for some real advice. I was nearing the completion of my build FINALLY. All I needed from the mechanic was to finish a vacuum hose or two and put the tune on the car. He was still encountering a little fuel issue so he decided to do a spark/fuel/compression test. Well everything check out except cyl 5, compression test only resulted in 80 psi, opposed to the 160/180 on the others. He added to the cylinder and redid the test and it went up, which leads me to believe it is a piston ring. There is no way I could afford to have him do all the labor, but at this point I am burnt out on the car and all the work. It is still going to cost money obviously to get the piston rings replaced, but I still have little to no desire to break this motor down AGAIN.
So heres where my options are... I could break it all down and bring the motor for a little rebuild, which I truly dont want to do at this point. Other one being to part this car out. So do I suck it up and break it down again or do I part it out. How much can be made from parting the car out?? Thanks for reading and hopefully someone can help me out. Thanks.
mustangmike98gt
suck it up and do it over and fix the damn piston ring! weve been waiting too long for u to just part out the car for some stupid ring. FIX THAT SHIT
I say fix it.
I know its really easy to get burnt out, especially after all the work you've put in, but keep going man. You know it'll be worth it once you're able to start cruising in it.
some people are going to take the title of your thread the wrong way, even thou you dont mean it....
castine917
wyoming, mi
1 hand fix it will give you the satisfaction. other hand selling it will give you remorse and regret. i say fix the ring of course!
JDwhite98gt
ARdoller said:
you have an oriental person stuck in your timing chain?
HAHAHAHA :laughing4: This is going in my sig. Anyway, fix that biatch, after all the work blood sweat and tears that went into the build, you're going to be really upset with yourself down the road if you get rid of her. I say break it down yourself then just bring him the short block and get all the rings and seals replaced while its there.
dafizuck
MustangChris said:
yea, wtf? just talk him outa there... he'll give up eventually...
I dont know man... means I have to learn Chinese first, I already have enough to do with this engine, haha. But for real, this thread was definitely helpful, need a little kick in the pants sometimes.
Any body have any idea how much something like that would cost (rings)?
birel21y
Rings arent the expensive part, its the labor. Why not get a clean used explorer engine, sell the heads, intake etc. and get your $$ back? I just built mine, and i gained money from utilizing the short block only.
Explorer engine- complete- -$425 SHIPPED (www.car-part.comhttp://http://) 180x8 comp. 89xxx miles
+$300 for heads
+$150 for intake set
+$50 for miss. explorer parts
_______
+$75
dafizuck
I dont have a 5.0..
I was thinking about doing that though with a PI engine.
greenscobie86
The Big Apple
I think you should stay on it. From your build thread, I'd say you put too much work into the car to let it go now.
Parting a car can be a PITA, I've done so(still doing so actually.) You have to deal with people wanting to buy parts or asking/answering lots of questions.
The car is complete, and a PI motor can be had for cheap these days so i think you can get it on the road with minimal costs if you choose to..
JMO of course...
Good luck with whatever you decide to do.
dafizuck
Id like to find a PI engine and just swap over the bullitt IM. Just cost money though... valentines day with a gf doesnt take much stress of the situation.. haha. I just want to drive this mother ...
birel21y
dafizuck said:
I dont have a 5.0..
Oops.. Duh. should of read your sig. Grab a used PI engine!!
dafizuck
birel21y said:
dafizuck said:
I dont have a 5.0..
Im probably going to sell the PI swap with bullitt IM and make close to my money back... i am going to be optimistic about it... haha.
reach down in between your legs... .. . . you feel anything there? if so, keep the car and fix it... if not, get a geo metro.
dafizuck
Balls = keep car... got it. Thanks man, haha.
