Knocking sound coming from under the dashboard
cody0170
Ok so for the last few weeks i've noticed that when i am at around 1800-2000 rpm's decelerating i have a almost like a quick knocking sound coming from around under the dash board. But if i depress the clutch within those rpm's then it stops. This sound is driving me crazy. What and where do i start?
2slo95fiveoh
Lawrence, Kansas
sounds to me like the throwout bearing is going out in your transmission. generally, the worse it gets, the more often
you will hear it. And the most common test to see if the throwout bearing is bad is to depress the clutch (like you stated)
and it generally goes away. to better determine this, get your car on a lift, with someone up in the car, have them hold the
rpms where the noise is constant, and listen from under the car, and i would bet that it is coming from the bellhousing area.
the part itself is fairly cheap, but it is the labor (if you choose to have someone else do it) is what will be slightly costly.
SRT Handz
something lost under the dash and the exaust is causing it to vibrate.
my fix....wack shit while you drive to fix the problem
C
cody0170
i replaced the clutch and throw out bearing within 4k miles. it only does it around 1800 rpm's or so. only around that not higher or lower. and when i depress the clutch in that range it goes away. sounds like someone is trapped by my gauge cluster and they are knocking. sounds exactly like that auctually
C
cody0170
stock replacement from a place here in Tulsa...."Tulsa Clutch and Brake" it was only like 150-175 for all
916_5.0
Check the tube that runs from your mid pipe to all you smog stuff they tend to touch the firewall and will rattle againsit when you drive mine did it and wheni would cruise or get on it, it would rattle against the firewall. So just see if thats rattling around.
+2 mine went out about 4 months ago,labor is expensive is about $350,yes to change a $12 part it sucks,with 2 10",an 800 watts amp slp's and off road h pipe cant hear it anymore :dancing6:
