leaking, radiator?
hottwheels04
danielson631 said:
i just recently replaced my original water pump with 122k miles on it and now that that leak is sealed up i believe it opened another leak up even more. im not exactly sure where its leaking from but its dripping off of the passanger side of the radiator.
im going to really look at it this weekend and see but anyone have any ideas of what it may be? do i need a new radiator?
on the corners of the radiators there are like, black peices that make up the entire corner, not sure what youd call that. i saw a little bit of coolant around there, is that where is could be leaking from?
im going to take it off and just get the radiator tested somewhere but any usefull information i get on here would be appreciated thanks
Go to your local autozone and for $4.99 theres a little silver tube of powder stop leak it works wonders, poor in the whole thing into ur radiator turn ur heat on high and let it sit for a little rev it up drive it and in 1 hour if its smalll hole it should work wonders, then next season drain the radiator / flush and put n new coolant and it should worth the $5 I did that and it worked for years, long enough until I bought my new radiator def worth the $5 :headbang: :thumbsup:
atlanticblue98
ummmmm.... you're like 2 weeks late. he already replaced the radiator
