Hi everybody.
I was planning on posting elsewhere but this forum's focus on the SN95 and lack of retarded user account requirements has steered me this way.
On to the project:
I want a car that will handle on the street or on the track. I can't justify a dedicated track car so a full cage is out but I do not require all the creature comforts and I do want to be safe so a custom roll bar, race seats and 5 point harnesses are part of the plan for my ~weekend toy.
Any way, through the floor subframe connectors were part of the plan until I did some research. It turns out that SFCs don't do much for torsional rigidity (resisting chassis twist), mostly they increase beam stiffness (resisting the chassis bending up or down in the middle). The way people increase chassis stiffness in first generation mustangs is rocker reinforcement and torque boxes to tie the rockers in to the cowl/front frame rails.
That makes sense from a structural standpoint because the section of the rocker can be taller than SFCs and being located farther from the chassis centerline moves the structure to where it can contribute the most to rigidity and it will increases the beam strength as much as SFCs or maybe more (due to the taller section).
I've got two inspirations for my tests, the first is the Mustangs Plus chassis stiffening kit which is essentially a weld on jacking rail, a convertible style inner rocker reinforcement and torque boxes (for first gen mustangs) and the second is an Agent 47 bolt in street cage for SN95s.
The Agent 47 kit used a bar that runs on top of the rocker which is a good idea except for the bolt in part.
I want to combine those ideas with a weld in jacking rail on the bottom of the rocker and a weld in side bar on the top. That will increase the section of the rocker a lot with only a slight increase in step over height.
I want to test it on my parts car chassis, before and after to record the increase of stiffness and make sure I get the details right before my keeper goes under the knife.
Details still up in the air are how to tie in to the cowl/front frame rails and how to tie in to the rear suspension mounting points.
With a weld in roll bar I'm planning a rear seat delete and maybe a race style three link with a long third link that ties in to the base of the main hoop.
Front suspension is probably even more ambitious but I'm going to worry about the chassis first.
Lastly I've heard that '98 or '99 Mustangs started using a structural expanding foam in the rockers to stiffen things up, if I can find some good tech for adding foam, that sounds like a good way to solidify things.
This is a long term project, expect progress to be slow.
I'm not building this for any rule book or racing class but if you see something that would get me kicked out of an open track day, HPDE, drag strip, etc. please let me know.
Here is a link to the Mustangs Plus chassis kit:
http://www.mustangsplus.com/tech/chassis/index.html
Here is an article on the Agent 47 cage:
http://www.mustang50magazine.com/techarticles/m5lp_0607_2003_mustang_cobra_rollcage/viewall.html
On to the project:
