Looking for 94/95 automatic transmission shift cover assembly
maillemaker
I'm looking for a 94/95 automatic shift cover assembly. With the overdrive on the cover.
Also, does anyone know how to get the OD switch out of the cover assembly? Doesn't seem to fit through the hole. Maybe I'll have to pull the leads out of the connector where it plugs into the harness.
RAU03MACH
NEW MEXICO
should be some little clips around the bottom
if you can get a closer shot of it well figure it out of that switch
maillemaker
I ohmed out the OD switch at the connector. Not getting any continuity when the button is pressed. This is just a simple momentary on switch, right?
maillemaker
There are little clips (well, there is one of two left), but they prevent the switch from coming back out the top side. I don't think the switch is removable from the bottom side. Won't fit through the opening.
So this switch must have been wired into its plug after it was snapped into the bezel.
Unfortunately I can't figure out the release mechanism for the sockets in the plastic socket. Normally you can put a pin in the hole and then back them out. I can't get these to back out.
Might have to cut the wires and splice back.
hazel113
