Looking for recommendations for 3.8 cold air kit.
Mach1Mark
South Caorlina
I ordered a cheap, chinese made kit from ebay and it was total garbage. I almost threw it away rather than return it. I knew better than to buy a cheap setup but I might get lucky. It has happened on my other Mustangs. Thanks for your recommends.
shovel
Considering the 5.8L Cobra R uses the same air filter as a 3.8.. I think the stock one probably flows fine. If you want to improve horsepower with bolt-ons go true dual exhaust and high ratio rockers. Neither of those is $79 on ebay but unlike an ebay intake those bolt-ons actually work.
badass98svt
And gears!
shovel
I got a rear axle from a Mach 1 for my wife's 02 V6. 3.55 gears, limited slip, vented brakes, quad shocks. It's about a 8.5% increase in torque at the wheels in any given gear. I used a Diablo programmer to correct the speedometer/odometer.
Since split port 3.8's have decently flat (enough) torque out to their redline I think 3.73 might be better at least on an automatic (14% deeper than 3.27) but the Mach 1 axle is such an easy afternoon bolt-in that bundles several improvements in one job that I think it's the way to go for upgrading a stock V6 with open diff 7.5" axle.
STITCHSCREWW
