lookn at traden da 95
MustangJunkie
lookn at traden tha 95 for a 98 how will i tell if its 2v or 4v and is there any thing i should look closly at i dont know much bout tha 4.6s mainly tha 50s n e info would b helpful thanx
pp_puncher
the 4v won't have a standard intake manifold or throttle body, it will be very apparent. Just search for 4v swap and you should see the manifold.
As far as other things to look for?! IDK, I guess the usual stuff....
badass98svt
4V has HUGE heads compared to a 2V.
Here's what a 4Vs cam covers and intake(96-98) will look like. But unless you are going to look at a Cobra, it's probably a 2V. Or someone swapped the 4v into a GT/v6 car.
MustangJunkie
thanx 4 da info guys im just gunna cross my fingerz hope everything is cool with tha car so i can finally get out of this fugly a@s green
sneakypete_ftw!
94 DropTop said:
Good luck to ya. Please start using real words that **** is hard to read.
x2! but 4v's look WAY different than 2v's. like he stated the intake mani, tb, and valve covers are very much different and the 4v heads a monsters compared to a 2v.
duff daddy
4v's have oval exhaust ports, 2v are more rectangular. Same with intake, 4v's will have an imrc spacer under the manifold and above the head. also a 4v will have an oe windage tray if its a cobra motor. Stock 4v blocks are all aluminum.
pp_puncher
LOL, I don't think he is going to be able to disassemble the engine before he buys it, but useful info none the less.
MustangJunkie
thanx duff im sure ill have a lot of tech ?'s if i get it. i just want some visual anwsers like i said before dont know much bout tha 4.6 always been a fox and 5.0 guy
ARdoller
-Never Forget-
Unless the guy says the engine is swapped, you're only gonna find a 4V in a Cobra.
sneakypete_ftw!
^man speaks the truth. every non-pi 2v i have ever driven, rode in, or ran against was a turd, not saying they can't be fast just that most aren't. if it is a non-pi car and you like it then i'd look into doing a pi head and intake swap. a buddy had one with full bolt ons and 4.10's and it was pretty quick.
