Low Coolant idiot light
Daryl
SoCal
Reservoir and radiator levels are bang on balls accurate. Coolant low light comes on… and as you can tell by the Temperature gauge, I just started out on an errand.
Chip66
Wildwood, MO
Mine did the same. I tried cleaning it but it didn't help. LMR sells a new one.
I'm under the hood enough and used to watching my coolant levels, so I just removed the idiot light bulb.
Daryl
Daryl
SoCal
image.jpgIs something supposed to be attached to these 2 tabs? They’re located at the bottom of the line that goes into the radiator reservoir.
Daryl
Daryl
SoCal
Crickets!…
I did put the dielectric grease on those metal tabs
Mustang5L5
The two tabs just measure conductivity of the liquid between them. The coolant basically shorts between them and make a connection. If the tabs are submerged in liquid and the light stays on, the sensor is likely bad and it needs to be replaced.
EdgarR213
