zincmock03
- Joined
- Mar 29, 2009
- Messages
- 8
- Reaction score
- 0
hey guys, i have a 97 gt with 140k on it, I bought it a couple months ago for my engine building class and figured i would use it as my daily driver when i was finished with it. It ran fine before i tore it down. It did not need any machine work i just put all new bearings, checked all clearances, replaced wear parts (timing components waterpump, etc). Also put in a set of comp cams the stage 1's and did a 3 angle valve job on heads. I started it up today and it runs fine and sounds good. I noticed the oil pressure gauge was reading nothing. When i rev'ed up it would go up and come back down at idle. I threw a manual gauge on it and at idle i have about 9-10 psi and at 3k i have 20psi. Book says i am suppose to have between 20-40 at 1500rpm, and i had 10. I tried searching and could not find anyone with my same problem. Any possibility it has something to do with the cams, i dont see how it would but just a thought. Some people say oil pump, but before the rebuild was fine and i did nothing to it.
