low rpm grind
lrall
Looking at another thread made me think of this. When im cruisin around and i go through a corner in 3rd gear or maybe slow 2nd gear and my rpms get low they seem to grind or nash together and make a bad noise. Is this just the T5 awesomeness or whats the deal?!?
L
lrall
2000, but the t5 went up until early 2001 I thought?
duff daddy
NO ---- Google FTW
When it comes to buying a Mustang clutch or a Mustang shifter, it is important to be able to identify which manual Mustang Transmission is installed in your car. Please note that Ford not only changed the type of transmissions used in different year and model mustangs, but also changed the size of the clutch disk as well.
In order to identify what kind of Mustang transmission you have, you need to check the door tag on your drivers side door jam. If you look down to the bottom right of the tag, you should see an area labeled "TR." Underneath this label there are 5 letters and numbers. The only one that we are concerned with is the first alpha-numeric character which corresponds to your Mustang Transmission.
If you have a 6 as your first digit, you have five-speed manual, T-45 OD Mustang Transmission. This is the standard Mustang transmission that is found in 1996 to Mid 2001 Mustang GTs as well as 1996 to 1998 Mustang Cobras. If you have a 5 as your first digit, your car came with a T-5 OD Mustang transmission. Finally, if you have a K as the first digit in the "TR" code, you have a TR-3650. This Mustang Transmission is found in mid-2001 to 2004 Mustang GT, the 2003 and 2004 Mach1 and the 2001 Cobra. The 2005-2007 manual Mustang GT's also a T-3650.
