Mach 1 gauge cluster???
amy98gt
Summerville SC
can you adapt the 03-04 gauge clusters to work on 96-98 gt computers or vise versa?
I'm really not happy with my aftermarket white face gauges and would love to swap to a Mach setup.
DeepList
Auburn, IN
Not to mention, the PATS will also cause an issue unless you can get the dealership to re-program them for you. The car won't start either. When I put a new gauge cluster in my V6 that I used to have, I had to start the car with the old cluster in it, then swap it out while the car was running with the GT cluster. Then I put the trim bezel back on and drove it to the dealership. I left it running outside and told them I need my pats codes re-programmed, but I didn't tell them that I changed the cluster out. It worked. They drove it around back and re-programmed it and never asked me why.
wildride02gt
Canton, GA
actually, with w few minutes of your time, you can combine a Mach/Bullitt cluster and a GT cluster to get what you want. I bought a Mach 1 cluster, swapped the electronics backing off of my 02 GT's cluster, and it all works fine.
You have to disassemble the two clusters. Separate the electronics from the cluster faces, and swap them. Take your time and keep track of all the parts. If need be I can dig out the leftover cluster assembly pieces and walk you all through it.
I always thought they looked out of place to me. Looked like something that might have been a lincoln or something.
