Its fun going faster then everyone thinks you can, with no where as much HP as others. 80% driver 20% car
which brings up a good point. The first time I ran the car that day I was lined up to an RX8 w/ a carbon fiber hood and a big stupid wing. I was lined up next to him in the staging lanes so he knew he was going to run me ( at that time I had no idea what he run b/c usually when someone asks you what you run it means they are slow lol ) so he asks me hey whats that run? I said I have no idea I have not been back here for 3 yrs and Ive done some stuff w/ it since then but the last time I did run it I got a 12.5. His very next response was....well I'm putting a turbo on this and I'll be getting about 450 HP ( In my head I golf clapped and said yay for you ). After the run it all made sense b/c he knew how slow he was so his next response was ....well I'm going to have XXX HP giving the impression he will be fast or soon to be fast. Well I destroyed him in the 60' a 2.9 to my 1.82, by the 330' mark he was a faded memory, by the 1/8th he was a small faded red dot in my rear view and when I hit the 1/4 mark the distance was somewhat comparable to the distance between Voyager 1 and San Diego CA. He ran a 17.0 @ 83 to my 12.7 @ 110. Point being his biggest concern is not his HP, its his horrid driving. Yes that RX8 is a total turd HP wise but how about getting some traction and learning to drive it before you start throwing more power at it. With a 2.9 60' at that power level what do you think that would turn into with more power thrown at it and still running on street tires? Some people will just never get it and for the ones that dont stay the hell out of my lane w/ your stock tires tearing up all the rubber thats been laid down lol
nice job man, do you datalog so he can adjust the tune? Did you pick up any mph since you last ran it?
We did not do any data log but we may be fine tuning it later on. When I was running it before I would avg a 106 / 107 every now and then Id get a 108. I ran two and would have been three if not for hitting the rev limiter 110MPH runs and I know there is a few more left in it. So say I can get a 112-113 out of it once everything is sorted out that would give me a 5-7 MPH increase over my previous average.
what kinda power you making and nice times btw
Thanks. Its somewhere in the 360-390 range to be trapping a 110 MPH Avg. I'll know for sure once I get back to the dyno. The last time it was on the dyno it pulled 348 with the screwy tune.
Lol was someone saying his car wouldn't go mid 12s? Id say with his power he could dip into the 11s easily
Thought he was making 350rwhp way back and the tune situation was finally resolved so it should be making closer to 400 rwhp right?
Nice times, 60s look pretty solid.
How are you launching?
Id like to know who that was if they did lol. Unless I miss a shift or hit the rev limiter ( It was set at 6,500 which is where I decided I wanted to shift it so keith raised it while we were there) It wont see 13's. I was happy w/ the 60' b/c my best was a 1.66 on slicks dropping the clutch off the line at 5,000 RPMS so cutting a 1.7 on the DR's was great. The best I ever got out of those w/ the old suspension set up was a 1.8. I was launching between 4,200-4,500 off the line w/ a slight clutch slip b/c the tires started to grab really early on. I did not see if they would dead hook at that RPM or higher but I think they would have.
I knew I was not going to get in a lot of runs that day so I stuck with what I knew was safe...no power shifting..no clutch drops off the line. I can shift pretty well and I knew the tires would hook w/ a little clutch slip so I stuck with what I knew would work knowing I can build off from that. Being that it was an actual event day and I was just running test and tune the most runs I could have gotten in was about 5 anyway. There will be other times coming up soon where I can go all out, I just wanted to get used to the car again and driving at the track. I was nervous as hell at the line and in the staging lanes on my first run. I kept thinking I would screw up my burn out, the launch or miss a shift. Neither happened b/c its just muscle memory and it all came back as if I had done it the day before. The fact that my first run went really well gave me a lot of confidence. I was not looking forward to 2-3 trips to the track just to sort out my shifting/burnout/ launch/
For those of you wondering why I am running the DR's over my slicks its b/c of two reasons. First one is I needed to get a sticker for the car. I had an inside source at a place who was going to give me a hassle free sticker. As the car was w/ the Cobra R's on the back and the Nitto's I thought I would be pushing it even though I was getting a lenient sticker. My Nitto's had been rubbing on my inside fender and the lip on the tire before you get to the side wall ( side tread ) was chewed to hell b/c of more then one encounter with the fender before I got the chance to give it more clearance. Also the Nitto's were on their last legs. The middle was down past the wear bars and the sides of the tires were at the wear bars. So I knew I was being given a favor for getting a sticker and I did not want to take advantage of it or push the issue by going in with bald nitto's and a one that was chewed up on the side. So I made the switch over to my weld wheels and my MT DR's which have a good amount of tread left on them and they dont hit my fenders ( Even with launching that day at the track). So my slicks came off my weld wheels and the DR's went back on. I did not want to buy new tires for the Cobra's until I roll the fender w/ an actual roller and I plan on stepping up to 18's so it made no sense to buy new tires for my 17's
The second reason is b/c of the sway factor at the top end of the track with slicks. Some of you know this, others may not but when you run slicks w/ full size tires on the front it creates a swaying effect at higher speeds at the end of the track. You can literally feel the car swaying back and forth, Ive almost lifted a few times b/c of it. The way to correct this is to run skinny's on the front. I have wanted to avoid this b/c I really hate that feeling and Id hate to have a good run going and have to lift at the end for fear of things getting a little to out of hand. I plan on running slicks this yr but I need front skinny's first and considering the DR's are hooking well I have no issues with using them for awhile. If for some reason I cant get the front runners by the end of this summer I'll switch the DR's for the slicks anyway just for some final few trips for the year. My goal is to have the skinny's and slicks on by Tasca day in mid Aug.
