Make Sure To Replace Your Belt Tensioner..... Mine Was Causing Issue.
SRT Handz
For almost 2 years now my car has acted very weird in the Higher RPMs (above 4,500)..... When i would start getting past 4K, My lights go dim and I get a HUGE voltage drop. My battery Light would come on but then once I shift and the RPMs drop, the voltage comes back.
Nobody could solve my problem, but I had a Large feeling it was my 140,000 Mile belt tensioner causing the issue.
Well this friday I started my car and got a squeak from a pulley. Belt dressing made it WAY worse and it was screaming. The noise was coming from the bearings on the tensioner failing.
So I replaced the tensioner with a OEM Ford unit.... Now My Voltage drop at High RPM's is Fixed!!! My car also pulls harder in the High RPMs because my ignition isnt getting overwhelmed with low voltage.
Remember to Check your belt tensioner Over time to make sure it operation properly.... It could be causing you issues!!! :book1:
lrall
Just an FYI, belt dressing is a big no-no for modern day belts...says mechanic (x3) that i used to run parts for
SRT Handz
OnyxCobra said:
You had a large feeling it was the belt tensioner but waited 2 years to replace it? :wave:
Yeah, It was on my list of Things to fix but there was more important things that came first. It wasnt really causing drivability issues and the problem was intermittent so i was just gonna wait till something broke then fix it.
mygreengt
South Dakota/ Iowa
right after i let it up from the floor i can hear the belt squeek from the high rpms. is that what it would do?
idk if that makes sense or not
JiMi_DRiX
Tucson, AZ
Mine was squealing, and you could see where the belt had rubbed the engine block some. I replaced that and the idle pulley, all better!
and belt dressing is a big no no!! that stuff is gross and messy.
DropTopPony
South Jersey
Bad tensioners are common on early 4.6's since they were aluminum and bent. The newer versions are steel and much stronger.
SRT Handz
Zwolaver21 said:
how much was the tensioner? I have been needing one.
It was $104 from dealer..... But i got it for $84.00 because i know a worker.
i replaced mine my first week of owning the car.
some people also remove the "stopper" on the tensioner to give it a longer "tavel path" ...
I got an autozone one for $69.00... it lasted roughly a year.
I got a NAPA one for $99.00... its a much higher quality unit.
