Misfire cause?
d.garza18
TEXAS
Recently installed a dorman intake mani on my npi 2v and the car fired right up but it didn't sound to healthy it had a misfire and almost like some cylinders weren't getting any pressure? It's just lacking power and I'm assuming its because of the miss. She also puked some oil so I replaced the gasket underneath the oil filter(forgot what its called) and that solved that problem. The cats do sound clogged so I'm assuming that's what causing the miss? Plugs and wires are all good as well. Should I go ahead and but he cats? Any help would be very much appreciated! Im still learning so please feel free to correct me and point me in the right direction!
d.garza18
d.garza18
TEXAS
Coolant/water tracts its way into the plug holes. Pull the plug wires out one at a time to see if any water.
:wink: I pulled the plugs and nothing? I even blew them out to be safe but no signs of water down in there. It did leak before with the old intake and would misfire but now I have the dorman on and can't find any leak.
d.garza18
d.garza18
TEXAS
Have you tried pulling codes?[/QUOTE haven't got the chance to pull any codes yet but I did figure out the Miss I had a wire I'n the wrong spark plug port lol, but the car is idling fine now it's just taking a crap on its self when I give it gas still no power I'm assuming bad cats are causing valves to float and restricting air?
d.garza18
d.garza18
TEXAS
Got it! Was a bad cat, it was crumbling so I dropped the midpipe and gutted it. Car finally has power again! Just need a quart of transmission fluid and a radiator and I'm good to go! Jw does anybody know why the Damn thing has six catalytic converters lol??
evilcw311
Most Evil Member!
Louisville, KY
Cause the government hates horsepower. It’s a conspiracy. They think if they make us slower that we won’t run.
