motor mounts solid or poly???
seth_96_gt
hey guys i need to order up some new motor mounts for my 96 gt.... so wats the main difference between solid and poly mounts the only thing i can think of is more vibrations with the solid mount i dunno tho
Pennywise2
Get poly motor mounts if your mustang see's mostly street driving.
Just make sure you pick a reputable brand.
Only get the soild motor mounts if your mustang is a track only car.
DropTopPony said:
I'm going to get another set of stock when i replace my engine. They are pretty good.
stock, i feel are the best bang for the buck, but poly is the overall best quality. If money doesnt matter, go poly.
Jetsetter
I ran Energy poly on my car for three months and switched to MM solid after wrecking it. I seriously can't feel any difference between poly and solid, and they seem to make it shake equally.
Willis_98GT
DFW Texas
i have the energy polys, it seems like the motor sits a little higher then it used to. but i mean its a good motor mount,
seth_96_gt
so energy polys sit a lil higher thats wat i kinda want after installin longtubes my stock one were so shot the driver side header is just barely rubbing on the steering shaft so ya any ideas of which one will sit higher?
Pennywise2
The Energy Suspension poly motor mounts are a reputable brand
to get.Alot of mustang enthusiasts use these motor mounts
without any issues.
Willis_98GT
DFW Texas
bend the knuckle out on the steering shaft a hair, i'm about to have to do that because mine started hitting a few days ago.
x182dan
I have energy suspension poly ones and they seems pretty good I do get a slight vibration but I cannot tell you for sure if its the motor mounts.
my solids raised my motor up nice and high.
plus the perk with solids is you can cut and re-weld them to lower your motor.
seth_96_gt
well i whent with a set of solids should be in any day now plus they were only 64 bucks for the set of em hoopefully they lift the motor enough so my steering shaft doesnt rub
