Motor mounts?
Anchor-Room
Many people use a board under the oil pan with a jack. First support the motor with the board and jack, support only, do not lift! Loosen all the nuts/bolts on one side , I believe there will be 3. Use the jack to lift, since one side is still connected it will force the other side up. Replace Mount, Tighten nuts/bolts > Lower, thread and tighten last nut. Repeat for other side......
Hope that helps!
toyman
Never having a bad motor mount I'm curious as to what you saw or felt that made you want to change them.
Musturd
They wear out all the time I'm surprised you've never noticed that's yours are toast
toyman
And why should mine be "toast"? I haven't noticed significant rotational torquing of the engine under load. Are there other visual clues?
Musturd
Depending on the year of ur car having a blower. And all the torque that comes with it if they are stock mounts I'm quite sure they would be torn by this time. But hey who knows
red95r
SUGAR LAND TexSuhZ
usually they crack and rip. I know mine are bad im just not looking forward to changing them. on the 3.8 it was easy this 4.6 is crowded.
toyman
I'll have to ask but I suspect the mounts were changed when the engine was built a few years ago. Car is now stored for the winter but I'll follow-up in the spring.
