msd coil pack for 95 5.0 are they worth it?
hottwheels04
I have been hearing alot of hype over msd products, I have a built 306 h/c/i car and I have been swapping bunch of diffrent things on my car wondering if it will help with my tunning dyno problems I have been running the stock coil pack, I was wondering what the gain is of swapping to aftermarket msd coil pack on a 5.0 car? I have heard they are junk and others say I should swap the stocker out for the new msd? whats the gains of them
H
hottwheels04
coupe5ohh said:
if you do one..do them all..meaning..if you do the coil pack do the dizzy,cap,rotor,wires, and one of their ingnition boxes..
I am currently running msd distributor/cap and rotor and ford racing plug wires, and still running stock ignition and stock coil pack..why run them all? I was told I didnt need the 6al box so I sold it I didnt plan on doing a blower kept it n/a and the factory rev limiter is 6,250 rpms which is fine but I purchased the msd street fire tfi module coil pack which says can be used with stock ignition / replacement
ProKiller
PA
take a step back here. what tuning dyno problems are you having that you think you need a new coil to fix it?
H
hottwheels04
I HAVE a thread of all the problems and things I needed to fix and replace, before I head back to the dyno I wanted to fix and replace stuff hopeing I dont waste more money on a dyno / tune and have same problems or more and low numbers?
R.C.
