mustang no start
project97
just bought a new starter, ignition,power wire for the starter with the battery cable harness i have full battery power
when i go to start it the radio and the clock turn off and the ABS and air bag light turn on any ideas ?
Marvin97
Glasgow, Ky
Do you hear the starter trying to engage? Does it make any noises at all? Check your ground on the block, make sure it has a good end on it and a good connection.
P
project97
no it dosent try to engage, where on the block is it grounded too ? could it also be the switch on the clutch ? that acts like a nuetral safety switch ?
the block i beleive has 3 grounds. floow the ground wire off the battery. make sure both battery cables are clean, corrotion free, and have a secure connection.
test the battery and check the water level.
use a tester light on the starter maybe?
P
project97
im going to check all grounds tomorrow, i can get the starter to kick over straight off the battery with jumper cables
P
project97
is there any way to test that ? and how can i tell if an ignition switch is bad ?
$70.00 key from Ford?
check the wires to the starter. if jumper cables can do it, it appears that its between teh battery and starter (easy check, just look at the cables and the connections.)
if not, its between the igntion+key and starter.... not so easy to check....
Marvin97
Glasgow, Ky
Mine was grounded on the driverside motor mount. I had the same issue your talking about, and it was a bad ground.
