My 351W 94 project
strokin94
not yet. should be on the dyno to get tuned within the next couple weeks, then itll be off to the track so i will let you guys know. the motor is estimated at just over 500hp at the flywheel
95boss351
i tilt my hat 2 a fellow 351w swapper. Nice bro. I did a efi swap n mine. ur heads and cam combo is great. Mine was an experiment. I will b pullin the motor at the end of the year
blackpony
Very nice bro!! Im interested in those numbers.. i am building a very similar setup except a 347 instead of a 351..
lilredstang97
nicely done sir. :thumbsup: i wil have to follow you and every one else when im ready to get started on my car but im going to stroke it and set it up for something a lil diffrent with a 351 block looking for a pepy motor with lots of tq
330CubeGt
Do the brackets on the front of the motor all bolt right up i know there like there on the 4.6 Vs 5.4 but was not 100% sure if there like that on the 302-351s I was thinking of putting a 351w bottom end in the car after i got the turbo on and the bugs worked out but at the same time a 331 would be nice...
BLOWN 95GT
Alabama
The brackets will bolt up to the three head bolts, but if you are planning on running the turbo from the 302 kit you will more than likely have some issues because the deck height of the 351w and 302 are different so you will probably end up having to lengthen the cross over pipe and maybe a few other modifications. Other than that you will need a different balance flywheel, and harmonic balancer, different lower intake because of the deck height difference, and some other things that I can't think of right off the top of my head.
Its got some goof info. Probably won't be locked.
Maybe one day the OP comes back and shares his knowledge with us.
96GTPlanB
