SVT Cobra #0042 equipped with a 351W out of a 95 Cobra R. The car has 80,080 miles and is rust free always garaged. Comes with the rear Cobra R wheels the welds and a sets of slicks if you what them. Currently has KDW2 front tires and MT DR's on the rear. The car has over $15,000 in modifications for the engine and suspension and other mods. Also comes with another coil and distributor. 100% NO TRADES ( Unless you have a Raptor). Mods are as follows.
For questions and serious inquires call or text 207 712 0020
Engine / Power
351W
FTI Custom CNC Ported 234 HR High Port Trick Flow heads ( Head spec sheet available. )
FTI Custom Camshaft ( Spec Sheet available)
Edelbrock Victor EFI Intake
PMAS 95MM Mass air meter
Accufab 90MM Throttle body ( fox conversion )
Tremec 3550 5 speed transmission with a pro 5.0 shifter
Exhaust
Accufab 1 3/4 Long Tubes
Custom 3"H pipe with cats
Magnaflow 2.5" Catback
Suspension
Team Z Tubular K member
Team Z A Arms
Steeda Bump Steer Kit
Maximum Motorsports lower control arms
Team Z Double adjustable upper control arms
Solid Spherical bushings
Strange 10 way adjustable shocks / struts with Coil overs.
Maximum Motorsport Caster Camber plates
Kenny Brown 6 point street cage
Sub Frame Connectors
MISC
Maximum Motorsports steering shaft
Autometer water temp / oil psi gauges ( dual gauge pod )
Ford Motorsport 4.10's / Mac Differential cover
Centerforce Dual Friction clutch
Engine / Power
351W
Exhaust
Suspension
Team Z A Arms
MISC
