N20 with S/C or Turbo
ripper
Turbo I dont know about but s/c yes. Your better off with a meth kit though. Its cheaper and does almost the same thing.
Knuckles@Empire
-Never Forget-
In front of you
you can run nitrous with any form of forced induction, small shots actually make te boosted are cooler and more efficient creating great horsepower gains, in the case of a turbo its also preffered if your running a big turbo it will help get you engine to boost quicker. but as always you have to be careful you cannot run to much but thats the same n/a or boosted. also a good tune is crucial because you ont want to chance any detonation.
supermech21
It does the same thing in cooling the Intake charge, yes...Power wise, no... Water injection (meth or Alcohol) is great to add if you re getting a lot of knock when tuning but if you want more hsp then go with a nitrous system. Water injetion will yield some power gains but their only going to come through on the tune. Its more of a safety thing. A small shot of nitrous is great for any type of a blower (like stated above), a small shot could help the Turbo spool quicker and if you have a roots type SC a small shot at the top of your powerband will keep the car from dropping off.... Good luck, i think its a good idea for anyone with a blower to get water injection, but thats just me.
ripper
Methanol injection cools the cylinders which in turn allows for more timing. This is were the power comes from. Im just afraid of a failure in the injection system and detonation. If the belt breaks on my s/c (which has happened) I only loose power not my motor. Im gonna stay away from it for now.
scott5
myrtle beach, sc
i want about 500 rwhp and i was going to go with a 331 stroker with a KB on top of it and was going to put a 50 shot of nx on it.
Knuckles@Empire
-Never Forget-
In front of you
theres a ton of different companies bud, pick something that isnt cheap though, in performance you get what you pay for most the time and when your building the bottom end its best to spring for the pricey stuff so you dont have to keep replacing parts down the line.
ripper
Stroker kit comes with crank, rods, and pistons I believe. PM Dalamar he just did a stroker. He is very thorough when researching products.
Shocker98GT
NX (others too I'm sure) has a boost reference controller that tapers off nitrous as boost increases. It's popular with turbos and especially guys running centrifugals, flattens the torque curve out when you want to have low end power or you don't want to deal with turbo lag.
BMOREstang
If you run it with a turbocharger you will need a boost pressure switch to cut off the nitrous at a certain boost level or until you want the nitrous to turn off.
