NE1 ON HERE RUN THERE SUPERCHARGED CAR?
Viper_Hunter
Has anyone ran there supercharged car at the track? i was just wondering what to look for on my car???
justinschmidt1
umm...i would say that a gt supercharged should run low 13s to mid 12s depending on other mods lower into the 12s...maybe 11s with slicks
V
Viper_Hunter
ya i just have exhaust and the vortech v-1 with fuel pump, fmu, and putting in 30lb injectors and 75mm maf on 10psi......i need a tune badly! :lame:
quickstang_1994
Cross Anchor, SC
Viper_Hunter said:
what do u mean i have to change the diaphragm?
the fmu lies to your computer to add the fuel that is needed with lower lb injectors to make them equal bigger (lb) injectors, but you are maxing out the 19lb injectors and you shouldn't use more than 85%of the injectors. The fmu has a diaphragm in it to adjust the fuel. Most people get rid of the fmu and just add 42 lb injectors because the fmu adds fuel pressure to get the fuel to the motor. If you use 30 lb injectors with the stock fmu, it will run the motor too rich. So it is cheaper just to put in 42 lb injectors and get rid of the fmu, but the car has to be tuned when you get rid of the fmu.
rjac
