Need a little help with my motor.
BlkoutGT
MO
Alright guys, I have basically rebuilt the top half of my engine. Stock heads/intake, new pushrods/lifters and frpp roller rockers and new gaskets everywhere. I've got everything back together and I cant seem to get this thing fired. I know you unplug the chip, put the #1 to TDC and point the dizzy pointer to #1. Ive tried all different positions of the balancer (its a new frpp piece with marks.) I get little burps here and there but nothing of a runing motor. Could you guys throw out some ideas of what could be wrong/ or missing or anything? And yes its getting fuel and spark. I'm out of ideas really, Thanks for any info.
BlkoutGT
BlkoutGT
MO
I thought that could be the problem, but I thought the dizzy could only go in one way. As in the plug thing faces out towards you when your looking at the motor. Am I wrong?
BLOWN 95GT
Alabama
Pull the dizzy and turn the motor over until you get the number 1 cylinder back up to tdc your motor could be 180 out. As long as the motor is tdc you can pick where number 1 on the dizzy is as long as thats where you put the number 1 plug wire and point the rotor button torwards it.
BlkoutGT
BlkoutGT
MO
Ok, Everytime I rotated the engine I left the dizzy in. Then pulled it out and put the pointer twards the #1 cylinder. But Blown95GT: Do I point the pointer twards the cylinder itself or to where the #1 plug on the cap is?
BLOWN 95GT
Alabama
You have to pull the dizzy, turn the motor until you get the number 1 cylinder back up top then stab the dizzy again. Just make sure that the rotor button is pointed at the number 1 plug wire, and you have the firing order correct.
BlkoutGT
BlkoutGT
MO
Hmm. I will try that. Aparently I have some bad info. If it works you sir have saved someones life lol.
BlkoutGT
BlkoutGT
MO
Thanks for the info and link guys. Another things that has be scratching my head is... I have a new Frpp balancer and the marks on say BTC and to the left of that is where the numbers start. I would assume btc means before top center. But I have always heard it refered to as top "dead" center. Any gueses as to why its like that? or is that the correct mark to start with?
