Need help- advice asap- egr tube issue
Maniac95
Egr tube is not in line and too short on new headers- has anyone had this problem and how and what did you do to fix this problem or make new tube. Cannot delete egr bacause of emmissions. Trying to get swap done today. Any input is appreciated,thanks
holley makes some simple screw-in extenders in 1/4"-1/2" lengths I think it is. The just screw in on top, then the egr screws into it.
Maniac95
I might need to make a custom one because the location on the header puts it further back ( towads firewall) and its about 1 1/2" too short. I dont know what material I could use to make another plus the fittings dont look like a standard 45 flare??? I dont think I am the first to have this problem. Thanks for the input.
Maniac95
Do you remember what you used as in material- if you used copper what size was it?
Paul
Cut and reconnect with high temp hose and a couple of clampl.
Don't do this. It will melt high temp hose.
There are spacers for the EGR that you can buy. Are the new headers stock-fit 94-95 5.0 headers?
