need help choosing tires
Bianner
so i need rear tires and i need help choosing wich ones would be the best. which ones would be the best for the buck?
Nitto NT 555R Drag
Ti
Toyo TQ Drag Radial Race Tires
Nitto NT 05
Sumitumo HTRZ
BF Goodrich G-Force T/A Drag Radial
Nitto NT555 Extreme
JoshHooten
Hiram, GA
the bfg's prob have the shortest life i had a set they were great tires super soft wide but not worth the money unless you go to the track and dont drive much you might get 2,000 miles on them i had a set and they lasted about 2 months and my car isnt a daily driver
they were 315/35-17
uncltrvlnmatt
Pa.
If you are not doing any racng DR's are a waist of money. I run Goodyear Eagles on mine, all the way around. But I see no track time. I had BF Goodrich G-Force all the way around. Got about 30k out of them, but they made alot of tire noise. I won't buy them again.
ProKiller
PA
nitto nt05 and sumitomo htr z should never be considered in the same comparisons.
first decide if you want drag radials or not. if so, NT05s seem to be the best out there but they wear fast. if not, then nt555rs are decent but there are alot of other decent tires out there as well. eagles like Matt said are good.
blkmcnasty
Illinois
i definetly wont buy another set of nitto 555. I run the 315's in the rear and they need to be heated up real good to get any sort of stick in them. I have no problems barking the tires in third gear on cold pavement. KDW's FTW.
MadStang
Escondido, Ca
Toyo TQ's are one of the longest lasting Drag Radials. You sacrifice some grip for that though. IMO, of the DR's listed they are the best dual purpose tire.
Only thing I don't like is how noisy my KDW tires are. I had 555Rs on my old wheels and they were a great street/strip tire, more traction on the street than a street tire but obviously not the best at the track. I'm guessing you want more of a street tire than a track tire.
B
Bianner
i want something that i can drive on everyday but at the same time has alot of traction when needed.
KWClutch
Nitto NT05 hands down. Wear kinda sucked but I hit a 1.6 60' putting down 450hp. If you're putting down under 300hp the 555's would be just fine. KDW's suck.
B
Bianner
right now i'm running the 555 radials on my car right now.
and for hp idk but the stock 98 cobra make around 305 i believe and as of mods i have a 200 warhn fuel pump, k&n drop in filter and bigger injectors but around 305 idk how much lol
and the NT05 i like how they look!
