Need Help Installing LEDs
heres the identification guide for our cars:
me having a convertible, i'm looking to switch my rearview mirror map lamps.
i ordered some red LEDs from amazon that were compatible with the original trade #.
here are my new bulbs:
here are the ones i'm replacing:
I clearly got the wrong ones because i had the wrong guide.
What series will fit in the bracket of the rearview mirror lights?
g36 monkey
Orlando, Fl
You'll have to get different LED's. I don't think its worth trying to rig something up to make it work.
Did you check Superbright?
clark98gt
Pennsylvania
Thanks Ferocious this will definitely help me out, now I dont have to depend on the goofballs at the local auto parts store to tell me which ones.
g36 monkey
Orlando, Fl
My buddy has the package for the normal dome lights from superbright. I just don't remember the part number off the top of my head.
g36 monkey
Orlando, Fl
Those are the ones, they are a bit touchy though. Need to find a way to get them clamped in better or something.
Justang
You are right, they're not the exact same size as the original but there's a simple solution for that one...
1. Place your thumb and pointer finger on the outside of the clamps.
2. Squeeze a little.
Ta-da.
g36 monkey
Orlando, Fl
I don't have a vert, but I imagine they are the same.
Justang, I figured as much. They aren't in my car, and we put them in my buddys car while it was deciding to monsoon. Along with the cluster lights and HVAC.
So, we were just trying to get er done.
Justang
COURTESY OF DALAMAR...
First thing I'm doing for the new year is ordering some LED's to do this mod
Trey is the man, and this is a great & affordable upgrade to do to your mustang.
So I just ordered the bulbs, cool white as shown.
I was thinking - why not do the dome lights as well?
Looking on suprebrightleds.com, it looks like they have a bulb that will fit that as well.
Here's my mini write:
DOME LIGHT TXCobra Style:
1- Pop off the lense cover with a small screw driver
2- remove the 3 screws that hold the dome light to the roof
3- disconnect the 3-prong power plug
Here you've got the light:
The dome light and accessory lights are the same bulb.
To remove accessory bulbs, filp it over, and pop them out.
you can pull up the reflector flap to give you a little more room.
Checking on the same site (superbrightleds.com) page 2 of the automotive lights, scroll down and you'll see the same type of cylinder shaped bulbs.
So they've got 39mm and 42mm...
mm to in conversion is .03937
So if I take 39MM(.03937) = 1.53"
So that should fit.
I checked in my F450, and it's the same dome/bulb, so I ordered a few for it also.
The bulbs I ordered are the 3910x6 LED Festoon Bulb
http://www.superbrightleds.com/cgi-...t=CAR&keywords=&cart_id=2279956.27931&next=50
I'll post up my results once it arrives.
UPDATE!
these put out a nice clean white light, brighter than the stock filiment bulbs, but not too bright.
PIX.
AS you can see they taper down on the ends - this makes them a little shorter than the stock bulbs, but they will still fit in the sockets.
squeeze the tabs a little closer together for a tighter fit
snap them it.
You can get the middle one, and could probably get the outside switched bulbs in while it's in the car.
I just pulled it out to inspect them and take pictures.
Here's the light output.
Center bulb, door switch. the light from 1 bulb.
The center and both sides turned on
Great info Trey!
I really like how mine turned out:
Hope that clears everything up for ya.
As an Amazon Associate we earn from qualifying purchases.
Justang
Pull your license plate lights out, swap those in, see if you like it. I think they will fit...it's a 5 minute task so give it a shot.
