NEED HELP OIL COOLER PROBLEM?????
GThang98
I NOTICE THIS MORNING THAT I LEFT A PUDDLE OF OIL IN THE DRIVE WAY SO I JACKED UP MY CAR AND THERES LIKE THIS REALLY SMALL PIN HOLE IN THE OIL COOLER AND WHEN TURN IT ON LEAKS OIL LOOKS LIKE A PERFECT CIRCLE I DON'T KNOW IF IT'S SUPPOSE TO BE THERE OR I MUST OF HIT A ROCK ON THE STREETS ANS CAUSE IT TO CHIPP OF A PIECE....
Steven
SC
take a picture and host it on photobucket, use the IMG tags and post it up. Kinda hard to know.. shouldnt leak at all though
Whistler98
Southwestern, Pa
Mine leaks a small amount but I think it is the gasket where it goes into the block b/c when the motor is cold it leaks once the motor hits operating temp. no more leaking. When it is hot out it doesn't even leak when I first start it. I just haven't gotten around to fixin it yet.
G
GThang98
i'll try but thr whole is very small i don't think the camera will catch it but i'll have the car on so you guys can see were it's leaking
nyuk98gt
GThang98:
That is a weep hole. It is there to tell you that the o-ring has failed or is in bad condition. I will check my Haynes manual (and, if I have to, the shop manual) to see if there is a write-up and then post back.
**edit: OK, p. 3-7 and 3-8 shows what you need:
* Drain coolant.
* Remove the lower radiator hose from the oil cooler.
* Remove the oil filter (you might as well change your oil afterwards in case you get some coolant into the oil).
* Use a 1/2" Allen key to remove the cooler from the oil cooler housing.
* Pull the cooler off the adapter (that is bolted to the engine block).
* Replace the o-ring on the oil cooler and the o-ring on the adapter housing. (Use a thin film of oil to lube the o-rings before you slip them into place).
* Re-install by reversing the above steps.
* Torque to 41 to 53 inch-pounds (about 4 lb-ft), if you have a 1/2" Allen wrench socket. Otherwise, snug up the Allen wrench but don't crank it down.
* Change your oil (Optional. I just added it for good measure/cheap insurance).
That should do the trick.
**end of edit.
Stay tuned.
Chris
G
GThang98
how can that o ring make that leak through the weep hole, i was guessing maybe the oil cooler got cloogged up, but if it's just that gasket the i'll do it
voidfinger
sorry but not to side track... how can you tell if your car has a stock oil cooler? i would like to know if my 98 gt has one. thanks
nyuk98gt
voidfinger:
Just to add to what Jrgunn5150 said...
The cooler is about 1.25" thick and the lower rad hose connects to the block right next to it. I am pretty certain that all of the '98's, auto and stick, came with an oil cooler.
Chris
Jrgunn5150
voidfinger said:
could someone take a pic of it??? , i would apriciate it O0
I don't have one, but it's pretty obvious, there are two braided lines comping out from between your oil filter and block.
