need help please!
87mustang
My 302 is blowing the dipstick out. Do I need to rebuild the bottom end? It's not running hot. :BangHead: :BangHead:Any suggestions please!
87mustang
87mustang said:
My 302 is blowing the dipstick out. Do I need to rebuild the bottom end? It's not running hot.rattling in the bottom end :BangHead: :BangHead:Any suggestions please!
95-stang
Either a blocked breather [pcv valve or similar] too much oil, or it could well be excessive crankase pressure meaning new rings\ rebore.
How many miles has it done?
87mustang
not sure bout mileage, just bought the car and going through it...auto meter gauges...holding 60 lbs of oil pressure...i also have a 351 windsor, thought about sinking money into it and swaping motors, what do you suggest? Thanks for any advice
LAFENATU
Like 95-stang said..
Excessive blow could be a clogged PCV or broken PCV.
Can also be a broken ring too.
94kingcbra
Pull out your pcv valve and shake it. It should rattle. If it doesn't, replace it. If it does rattle, then I would recommend a compression test to verify your rings are good.
sbr420a
60 psi is alot of oil pressure bro. my motor has 70,000 miles and it has about 22-28 at idle 30-38 at cruise and 40-50 at wot
birel21y
I would like to know too.. My car is doing the same. My PCV is fine, but im siving oil out the dipstick tube. I also have 235K miles.
