NEED HELP.... power seat broken!!
usanthony
hey all i got a 94 cobra,, there is some big wireing issues,, but i need to remove the drivers seat and it has no power so i cant get to the bolts.. any ideas?
kissrocksforever
Ontario, Canada
Re: no power to drivers seat!! how do i move it?
I had the same problem with my 94 GT
first thing you should do is check the fuse box, make sure there is a fuse in there and if there isnt put one in, if there is then replace it.
SN95.ohh
My power seat broke and would barely even move. I could get the front bolts out easy but I had to just fight with it to get the back ones out. Just have patience and try and find the smallest wrench you can and just work with it. Idk if maybe you could go under the car and get the bolts loose from there. I ended up ordering a manual seat rack and swapped it out. Who needs a power seat that your going to move once and leave it alone?? Plus it prolly saved me about 20lbs.
U
usanthony
Hey all.. i need some help.. my power seat is broke (94 cobra) im trying to get it out but i cant get to the bolts cause the seats wont move,, any ideas??
RockstarMentality
you can get in there with a wrench. if the wrench isnt long enough, use the box end of the properly sized wrench, and take another, slightly larger wrench to hook the box end of the second wrench around the open end of the first
they are run by worm gears and can collect an amazing amount of dust. When they do they jam up. If you can get them up enough to see the gears see if you can hit them with some wd40 with a straw and clean them off. Mine had locked up but thankfully they were up enough to get wrench under it. After removing the seat I cleaned the gears and the re-greased them and they have worked perfect since.
push the button and push the seats the same time.
maybe?
mine went out too and that was the only way i could move it
U
usanthony
Thanks guys! ill have to try .. im not really sure whats going on with it if its broke cause there is no power to the pass side either,, the door locks both sides,, so i trying to track down a electrical problem,, the guy that had it before me really did a hack wak job with splicing things,,
U
usanthony
i checked the fuses under the dash,, but i didnt know there was anything under the hood for that stuff,, could it be one of the relays? im up for anythign at this point..lol.. i was just gonna start cutting the damn seat apart its pissin me off
U
usanthony
ok i just checked under the hood,, i had a blow 30 amp fuse so i replaced it and wamo the seat works,, the one that was blow was not the right one for the seat so i guess i have some wireing issues..lol. but i did cut a bunch of crap out so mabye its ok... thanks for everything guys!!! hey if you all know anyone in need of a all tan interior for a 94 cobra i got one its in good shape
