NEED HELP WITH EXHAUST LEAK
parkinlotpimpin
WHAT I GOT ARE BBK EQUALS ON A MAC O/R X THEY ARE LEAKING ON THE PASS SIDE FLANGE THEY ARE THE BALL AND CUP STYLE
IS THERE A QUICK FIX SHORT OF STRAIGHTING THE FLANGES OR REPLACING FLANGES.sOMEBODY SAID I CAN SEAL IT WITH HIGH TEMP SILICONE. ALSO I KNOW THIS QUESTION HAS BEEN ASKED
WILL FOX BODY STYLE LT'S WORK ON A 94-95 VERT AND IF SO WHAT ARE THE BEST TO GET. THANKS
SoddyRebel
i wouldn't use any type of silicone, just loosen the bolts again and make sure you tighten each bolt on each side of the flanges evenly.
LAFENATU
When you installed the X pipe, did you hold it up with a jack and made sure you lined it up perfect?
1bad95
the silicone wont last. I tried it before on an old cheap H that was on my car when i bought it. i would try taking it back out and make sure there are no cracks or bents around the cup on the midpipe. sit it back up in there and i always try to make sure to tighten each side equally to help make sure it seals. you can also try some of the high temp silicone if you wanted when you put it back together, but it just burned out of mine within a week or so
