Need help with ps pump
blkmcnasty
Illinois
recently when my i start my car cold, my power steering pump is chirping like a damn bird. Is this a sign that it needs replacement? If so can i get some direction on how to do this myself?
95DarkGreenGTS
Bossier City LA
I just took mine off yesterday. You need to rent or buy a powersteering pulley kit. Remove the pulley unbolt the pressure hose on the side of the pump. then unbolt the 3 star headed bolts and the pump lifts out, but still has a return hose attacted unhook it and its out.
Once you unhook the hose it will leak fluid! But mine had a leak so it already leaked most of it out. LOL
two95s said:
Are you sure it's not your belt?
Are you sure it's not the dizzy bearing going out. Mine made a similar sound.
Are you sure it's not the idler or tensioner pulley?
wm23n1
My pump makes that same sound. I was told it was going bad before I got the car though.
B
blkmcnasty
Illinois
My belt is new cause i just changed it when i did my Aluminum pullies. The idler pulley is on the other side of the motor so i can pretty much put my ear close to the PS pump and hear it making noise when a friend turns the wheel at idle.
B
blkmcnasty
Illinois
Thanks buddy, thats the info im looking for if indeed it is the pump
Paul
Make sure you have cfluid. Ppower steering pulley puller can be purchased from harbor freight for cheap.
