Need rear end specifics please
jwhisl
Oklahoma
Hello everyone. I have a 95 v6 with a 7.5 in it. I have read that I can take the axles and use them in a fox 8.8 and just use the disk brake setups. Has anyone here actually done it? If so can anyone provide specifics as far as housing length and axle length for both? Thanks.
Cpotts13
Biloxi, MS
I am confused at what you are wanting to do..
Do you want to upgrade to the stronger 8.8?
If so don't even mess with disassembling yours, 8.8's are a dime a dozen.
You will need a 94 or 95 model year 8.8 from a mustang, because this will come with the disk brakes and the correct length.
If you're patient and check your local salvage yard and craigslist you can snatch one up for $100-$300.
Magic
Some time zone
Actually, if the OP wants to swap in an 8.8 into his 95, any year 8.8 housing from an 86-98 Mustang will work.
8.8 housings from 86-98 are the same length. The axle shafts and brakes and brackets and moan braces from the 7.5 can be used. You can take the hard brake line off the 7.5 and use it with the 8.8 or make new lines.
As clark98gt said, it will keep the same width.
If you want to go wider (have the effects of using a small wheel spacer), then get a complete 8.8 (with axles) from a 99-04 Mustang GT as they are roughly 3/4 inch longer (per side) than the 94-98 setups.
Musturd
Yea you can swap shit over personally I'd find a complete 8.8 . The only reason I did it this way is I find it easier setting up gears on my work bench instead of having the diff in the car
J
jwhisl
Oklahoma
OK Thanks. That's the info I needed! I didnt know about the brake lines so that is very helpful. I will pass this info along to my mechanic when I have him do my swap.
