need some help!
MrNiceGuy
i've taken off my upper control arms and the bolt holes arent lining up.. they are the exact same as the stock ones i took off and it's barely off.. i've been playing with it for a while trying to get it to go on and i've had no luck.. i've tried lowering and raising the jack.. starting on the differential side and starting from the other side.. i just cant seem to get it to line up.. anyone that knows what they are doing care to shed some light on my situation?
1FastGT
i had the same problem as soon as i took my control arms off my rear end shifted towards the back of the car get a ratched strap you use for towing etc. and wrap it around the axle tubes. and somewhere around where the control arm mount too and get it tight and ratched tighter if you need it closer.
19mustang95
put the rear on jackstands and then place the jack on the front of the pumpkin by the driveshaft and use it to lin up the holes..
