Need some imput
scott5
myrtle beach, sc
Well i am in a dilemma. I am building a 331TT motor and it will not be done for atleast a year or so, so here is my problem. I just found a deal on a 67mm turbo for about 480, but i would have to get all tubing and stuff done for it and my car only have 24lb injectors and a cobra intake and 70mm TB.. OR i found a deal on a HCI for 1100. Its an Edlebrock Performer RPM 2 intake, Performer RPM heads, and a comp cam. And i already have spray so what you guys think i should do? Get the H/C/I and run the spray or Just get the turbo and put that on?
Spd0lit
SoCal
H/C/I it will allow you to have better flow, so if and when you do your motor you can suck up all the air you need.
scott5
myrtle beach, sc
ok i have decided on the H/C/I now, which set up should i go for cause a buddy he selling his also.. The Edlebrock stuffed i mentioned earlier or a holley systemax2 intake, Afr 185heads, And a comp cam also. (that setup with 11.9s on just motor and a tune (it was a 306 though)
Spd0lit
SoCal
holley systemax2 intake, Afr 185heads, and comp cams would be my choice because it will allow room to grow in the future.
