Jrgunn5150
- Joined
- Jun 29, 2007
- Messages
- 12,273
- Reaction score
- 2
Sorry if it's a re-post, I just got excited, is this the new "Hurricane"? http://www.nmratv.com/index.php?str...deo/racecoverage/milan07/Roush.flv&playlist=1
Shocker98GT said:Well, they said 5.4 supercar motor so I'd guess no. Hurricane engine is rumored to start off with a 4.015" bore and 3.74" stroke, which achieves 379 cubic inches (6.2L), and they're rumoring a shorter stroke 5.8L design for the Mustang, and the ability to go to a 427" displacement.
Personally, I think the engine should simply be a larger modular. As in, keep the fantastic block design elements, the oiling system design, and KEEP IT OHC. Don't follow Dodge and Chevy, put the nail in the coffin. Put the lovely 3V head design on the above block and it will flat out roast the LS or Hemi engines, maybe a 4V for higher performance applications. They were rumoring pushrods for a while, now some say it'll be SOHC and start as a 2V, etc. Ford needs to make absolutely sure that they put out a dominating engine and start the platform off right, remember what happened when the modular lineup was introduced?
95Grandtouring5.0 said:Thats just the problem though, without boost a over head cam ford motor will not make nearly as much as a ls series motor without cam and head work, and if you put a decent set of heads and cam on a ls1 it will blow it out of the water. The only good thing about their over head cam technology is how strong the blocks are, and with all forged internals can handle a lot of boost and push major horsepower. Without boost it would be very hard to get one of those motors over 400hp n/a. Chevrolet and Dodge had their eye on the ball.
Shocker98GT said:95Grandtouring5.0 said:Thats just the problem though, without boost a over head cam ford motor will not make nearly as much as a ls series motor without cam and head work, and if you put a decent set of heads and cam on a ls1 it will blow it out of the water. The only good thing about their over head cam technology is how strong the blocks are, and with all forged internals can handle a lot of boost and push major horsepower. Without boost it would be very hard to get one of those motors over 400hp n/a. Chevrolet and Dodge had their eye on the ball.
I don't know why people think the problem is due to the motor being OHC. OHC is the saving grace to these motors. If you designed a 281 cubic inch motor with a 3.55 bore size, and stuck with the 2V pushrod configuration it would mean an enormous power loss, it would be a DOG, substantially worse than our cars.
The 3V heads flow very comparably to the LS6 heads, that's measured on a flowbench set up for a 3.55" bore size. The 4V heads do even better. And this is done keeping enough velocity to maintain low end torque on a small displacement engine. Put those type heads on a 4" bore, reshape the chamber, relocate the valves a bit, it'll make more power AND more torque than the LSx and Hemi engines on the market. Bar none. Just look at the gains people are getting from these motors going to just a 3.7" bore size, most are gaining 30-40lb/ft throughout the ENTIRE rpm range with no other changes. 4" bore would be even better. And add enough displacement to take advantage of the potential headflow....it would murder anything GM and Chrysler have on the table right now. And it'd do it with less displacement, as long as the bore stays large.
Jrgunn5150 said:Ford could do alot of things, like made a better mod motor awhile ago, but they don't really want to spend 300 million developing a new motor so soon after the last I'm sure. I think they are just faced with the harsh reality that they are outgunned now.
95Grandtouring5.0 said:Shocker98GT said:95Grandtouring5.0 said:Thats just the problem though, without boost a over head cam ford motor will not make nearly as much as a ls series motor without cam and head work, and if you put a decent set of heads and cam on a ls1 it will blow it out of the water. The only good thing about their over head cam technology is how strong the blocks are, and with all forged internals can handle a lot of boost and push major horsepower. Without boost it would be very hard to get one of those motors over 400hp n/a. Chevrolet and Dodge had their eye on the ball.
For knowing so much about over head cam motors, you sure don't know that a 3 valve has better flow then a 4 valve. -_-. But im sorry to say, if ford could come out with a over head engine design that could blow chevrolet and hemi out of the water then it would of happened awhile ago. Regardless of whatever flow you claim ford over head motors to have, you probably could not show me one modular ford motor that makes over 500 horses by itself. I on the other hand could show you over a hundred ls series motors right off the bat. So until Ford actually makes this motor that you think will beat chevy and dodge. I'll just continue to laugh until something actually comes out that can do so. Until then. :hammer: :hammer: :lol: :rockyou:
95Grandtouring5.0 said:I could rip most of that post apart, if I had the time and didn't have to leave for work in a few minutes, but I will basically say until Ford makes a motor that is better then Chevrolet lsX series motors and Dodges Hemi platform then ford is just not there. Thats why it takes a super charged dohc motor to keep up with a convetional pushrod n/a ls2,ls6,ls7, and soon the ls3.
