New Fuel Tank Sump Setup
330CubeGt
This is the last project Keeping the car from Running an im almost finished.
(Put this in the Visual because there ain't a Fuel System Tech Section)
The Sump(Mustangs Unlimited)
Figuring out where to put it
Traced out,The Circle is where the Stock Basket sits i kept it in place to use the stock setup for the fuel gauge
Punched out some holes
Cleaned up the surface to get it ready to be welded
Tached the Sump in place but did not have enuff wire to finish welding it so i started to trim the plastic tank cover to work with the sump
Cleaned up the cover and used some light sand paper to smooth it out a little
I had Grey Primer sitting around so i figured i would try it out
Painted with some Random Fast Dry Enamal i found in the Garage
Another shot with it painted
Tank is Ready to go in once i get the sump fully welded on,Then all i need are a few fuel fittings and Install the MSD Pump, then i can try to start it again.
mod46stang
man i want to see the install tank on the car i always love the look what pump are you going with nice job on the tank
330CubeGt
Thanks man!
I got a Great deal on a MSD Inline Pump So im going to try it out, thats all i should need for now.
330CubeGt
I would if i could i don't even have the welding wire to finish mine. :angry7:
