New guy from Tennessee
5.0Fever
5.0Fever said:
Thanks for letting me join... so glad to be apart of this community.. I'm from Tennessee but working in florida at the moment.. I've had several mustangs over the years and stuff happens and had to sale them all... but just 2 days ago I bought a 95 5.0 5 speed 111k miles from the original owner who had it on jack stands and last drove it in 2011 it's been sitting since then drained gas put new gas and battery and started right up... the defrost was on and as soon as car started I heard compressor kick on... and started blowing cold air... CRAZY.. it's 100% stock couldn't pass it up the price was stupid stupid low
Sent from my SM-G935V using Tapatalk
5.0Fever
5.0Fever
He had it on jack stands in his garage for 2 years then had to move it out side and put back on jack stands.. he said he had a cover on it but storm tore it up and didn't do anything else with it.. Florida sun killed it
5.0Fever
Thanks and ya can't wait to start building it... I got it for 800 bucks
5.0Fever
Not sure what gears I'm thinking 373 is all around good gear
Nighttrain
Atglen pennsylvania
Thats what i usually go with. I drive mine so anything taller effects fuel mileage to much. H/c/i a little suspension work to get moar low, maybe a power adder and your good to go!
5.0Fever
I'm thinking about 306 bottom end a set of twins not sure... there's so many ways to go with it
5.0Fever
I'm used to driving my 4x4 dually everyday... so when I got in the car It felt I was just sitting on the ground
Nighttrain
Atglen pennsylvania
It takes some getting used to lol. I used to drive big trucks so even getting in my pick up felt weird. But you get that suspension dialed in.......look out corners.
Nighttrain
Atglen pennsylvania
Yup, keep in mind the 302 block is a little weak in the cam valley, so if you push it over 400hp its reached its limit. Most guys end up going with an aftermarket block like dart because of this. [MENTION=8095]ProKiller[/MENTION] is a good one to talk to, he built a brand new motor for his. This is the reason im looking to go with a mod motor. More room to grow, factory aluminum blocks are plentiful and easy to find, and are able to handle the ponies.
5.0Fever
Hmmm that's good to know thanks for the Info for the mean time I just wanna do a cam and throttle bodie and injectors I want a f303 cam if you know what will work with that cam aka injector size what else will I need to run the f cam just for a fun little street toy nothing major for a year or so
Nighttrain
Atglen pennsylvania
Not sure if springs are neccesary for the f cam or not, but imo i always go overboard. I want my stuff to last so id do springs, locks valve seals. 1.6 rockers are good to, youd need to check with frpp if piston to valve clearence is ok with that set up.
