Plan is to keep her NA. No real budget yet. First thing I’ll do is eliminate the clunky shifter with something smoother and closer to the driver. Either I have short arms or the shifter is super far from comfort driving. After the shifter probably do the rear end, the suspension and then intake, exhaust and headers. Then eventually injectors, heads and cam. I feel it will not be cheap. But this is going. To be a project purpose built daily. Not a garage queen or trailer queen. Just fun enjoyable drives to work. And the occasional mountain roads.
If keeping her na and if your set on the numbers you’ve mentioned then you’ll be looking at higher compression as already mentioned, a nice set of aluminum heads with some work done, a custom ground cam, and a nice intake matching the rpm range of the cam. You’ll be looking at a better set of pistons at minimum but I’d imagine a full set of internals.
It’s definitely possible but will take a lot of custom parts and will be expensive. This is why so many go boosted. Easier and cheaper.
I’d like to see a nice high compression build. Something else to think about is possibly a 351w swap. Plenty of guys have made big power with those naturally aspirated and it’s an easy swap that utilizes a lot of your existing parts. The extra cubic inches with some compression makes for a really fun motor.
