New Pic of My 95 Vert.
Adam95GT
Well since the car is slowly getting finished we took a few pics today. This one came out ok. :headbang:
A
Adam95GT
Thanks dutchy ill post more soon. Gotta clean up the bay a little but here is an old one while you wait:
dutch
mad props on the engine bay Adam, looks great!
A
Adam95GT
Thanks man!
I just tried to make a list of whats be modified or changed, im sure i am leaving stuff out i just tried to think of everything:
Shaved Engine bay
...0.030 Overbore 302
Keith Black Flat Top pistons
TFS/KPI HiPorts Cylinder Heads 2.02 intake valves
Comp Cams Pro Magnum 1.6 Roller Rocker Arms
Trick Flow Hardened Pushrods
Wolverine 1190 Cam
Trick Flow Track Heat Intake Manifold
Accufab 70mm Throttle body
Accufab 70mm EGR Spacer
FRPP Underdriver pullies
Trick Flow Specialties Valve Covers
Trick Flow Specialties billet fill tube
Custom 3'' Mandrel Cold Air Intake
PRO-M 24Lb Maf
24lb Blue Top Injectors
Walbro 190LPH Fuel Pump
Custom Accufab 1 3/4'' headers (3'' collectors)
Custom Mid pipe 3'' pypes cats V band connections
Flowmaster American thunder Catback
Aluminum Drive shaft
Tubular QA-1 K member
9mm FRPP Spark Plug Wires
Autolite 24's
MSD Distributor Cap and Rotor
MSD Coil
Lokar SS Braided Flexible Dipstick
MR. Gasket 180* Thermostat
C&R racing Aluminum Radiator
Moroso Overflow Tank
Steeda Aluminum Lower Control Arms
Eibach Sportline Springs
Tokico Hp Blue Shocks and Struts
Kenny Brown Camber/Caster Plates
Ingall's Engineering 17mm Camber Adjustment Bolts
Hunsaker Racing Seats
Battery Relocation
98 tails
Cobra R Hood
Chopped Antenna
Mach 1 Lip
Redline Hood Struts
FRPP Hood Pins
Line Lock
Slotted Rotors
New Brake pads
New Rear Calipers
New Master Cylinder
New Starter
SS brake lines and All new Hardlines
Low Mileage 94/95 T-5
MGW Shifter
Hurst Shifter Ball
Poly Motor Mounts
New Ultra Clear Head Lights
StangMods 6,000K HID's
New Ball Joints
New Power Steering Rack
Poly Offset Rack Bushings
Polly Swaybar Bushings
2'' Poly Endlinks
FRPP King Cobra Clutch (New Throw Out Bearing)
Mac Fire wall Adjuster
Clock Gauge Pod
Cluster Surround Gauge Pod
Autometer Sport Comp II DPSS Stage 2
Innovate LC-1 Wideband with DB Gauge
Autometer Sport Comp II- Electric Water Temp Gauge
Autometer Sport Comp II-Electric Oil Pressure Gauge
New Convertible top lift cylinder
Cobra R Wheels (17x9 fronts with 245/45/R17's TOYO Proxies 4, 17x10.5 Rears with 315/35/R17's)
Tuned With: Moates.net Quarter Horse and Clint Garrity Binary Editor and EEC Analyzer
25lb weight removed from fender
Dogbone Removed
Rear Seat Delete
A/C delete
Smog Pump Delete
Quad Shocks Removed
Shortened Dayco Belt
