new problem..
white 98 gt
hey guys, maybe you can help me with a new problem. when i'm slowing down from highway speedsmy rpm's suddenly drop instead of doing it gradually. all my vac.lines seem ok. i used to be able to make it stop using my cruise control, but that doesn't work anymore. tried unhooking it from my throttle to see if that made a difference. nope. anybody else ever have this before? thanks for any help...
W
white 98 gt
no one else has any ideas? think i'll change my tranny filter & fluid, it's due anyway....
atrainsgt
Do you have an auto? I don't think its your transmission causing the problem. If it was slipping, your RPM would rise.
atrainsgt
white 98 gt said:
yeah, it's an auto.
It sounds IAC related to me as well. I would replace the IAC. Cleaning them doesn't always work.
C.Hunt1006
ya sounds like either your IAC or your crank sensor. check the crank sensor and clean the connections
W
white 98 gt
ok. i'll get another iac & check the crank sensor. thanks guys. what do ya think about the throttle position sensor? whenever i get it fixed i'll let you guys know what it was...
atrainsgt
I doubt its the TPS. I had a dead TPS on my motorcycle and had no ill effects from it. I realize that's not a fair comparison though.
