d.garza18
TEXAS
I’m to lazy to go back and read it all, but exactly was your motor build up if you don’t mind me asking ?
98snakehorse
98snakehorse
Southeast, IA
Factory Bore Romeo Block
Stock PI Heads
CMS Cams and Springs
Factory Romeo 6 bolt steel crank
Boss Rods
Mahle Pistons -16cc dish
Factory Head Gasket and head bolts
ARP main bolts
Pretty simple stuff
d.garza18
TEXAS
Stock PI Heads
Boss Rods
ARP main bolts
Pretty simple stuff
Thanks man, mind if pm you some questions about it?
98snakehorse
98snakehorse
Southeast, IA
what’s your rear end setup? Like suspension and diff setup
8.8 31 spline Eaton LSD / 3.73 gear / Moser 31 spline axles,TeamZ upper and lower double adjustable control arms with the solid heim joints. Ford B springs that I cut to my height liking, strange 10way shocks. TeamZ Extreme Anti Roll bar. deleted sway bar.
joshuaw3
Ohio
No issues with your power level? I’m planning on making 800+ hp in the future and would like to drive it on the street some but will mostly be a strip car. Was thinking of going spool.
98snakehorse
98snakehorse
Southeast, IA
Well a little update on the mustang... I got my turbo kit sold and most of the intake manifold stuff. If anyone is willing to travel to SE Iowa I can get you a killer deal on the 4.6 2v long block that's mildly built.
joshuaw3
Ohio
What’s the killer deal?
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
What’s your plan for electronics with the coyote? Are you going to do a stand alone system or use the ford control pack?
Mikehonco69
