nitrous intake plenum spacer
mtang98 gt
i just recently got a intake plenum spacer that is drilled for the nirous fogger nozzle to screw into. Do i need to get my car re tuned for the repostioning of the nozzle?
IceMan
Does the spacer have a rail going through it for an even distribution of the nitrous, or is just the nozzle in one of the ports.
mtang98 gt
mtang98 gt
You screw the nitrous fogger nozzle into the spacer just like you would into the air intake. so yeah no rail or anything just a hole you screw the fogger nozzle into it.
IceMan
To be honest with you I wouldn't do that if I was you, because you wont spray the nitrous in all cylinders equally. As a matter of fact you will only spray it in one port. This is how it should look. Notice the bar going across the port holes? That's for even distribution. If your spacer doesn't have that, than I wouldn't spray that car if I was you. You will do some damage.
Untame-d
^ very true.. Need even distribution.. even fog kits are known for pooling sometimes if setup wrong.. pooling = boom
jabird
The spacer type nitrous plates are generally for carberated applications. The fuel/air ratio is critical or you will blow that sucker... :angry7:
mtang98 gt
mtang98 gt
well i dont want a boom so ima just sell this thing. good thing i got it for free haha.
